Surface Enlargement Factor of a ribbed Surface |
November 23, 2017, 08:10 |
Rep Power: 11 |
Hello everyone,
i want to simulate a simplified geometry with the same Heat Flux of a ribbed Surface and my question is how do i do this? For clarifications: I have a ribbed plate and a known Heat flux of X W/m^2. Now i want to simulate a flat plate and want to get the same Heat Flux of X W/m^2. I already know that i can achieve this through rough Walls and to determine the roughness height and constant iterativly, but it is kind of bulky. Thank you for your help. |
November 24, 2017, 05:13 |
Rep Power: 143 |
If you know the heat flux of the boundary then just use a heat flux boundary condition.
November 24, 2017, 05:30 |
Rep Power: 11 |
I think I have to be more clear on this side.
Lets assume we have a plate with a source in itīs inside and i want to get the same heat flux at the fluid boundary with a ribbed and non-ribbed plate. I could get a factor for the flat plate to achieve this. Now, i want to adapt this procedure to a more complex geometry. For this geometry the heat flux at the boundary is not known but the mentioned factor. Furthermore, the ribs are too many and complex to model/mesh them, thatīs the reason why i want to get this factor. Btw. it is essential, that i have two bodies - the plate and the fluid. |
November 25, 2017, 05:31 |
Rep Power: 143 |
In this case I recommend you look into heat transfer textbooks for thermal resistance. You can determine the thermal resistance of the flat plate and the ribbed plate and use the thermal resistance as the heat flux at the boundary.
This is assuming thermal resistance is an appropriate model for what you are trying to do. |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 10:51 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 09:20 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
