Shear rate dependent chemical reaction rates
Old   December 19, 2017, 02:37
Default Shear rate dependent chemical reaction rates
cardioCFD is on a distinguished road
Hello
I am trying to define some reactions with shear rate dependent rates in CFX, i.e, reaction rates are higher when/where shear rate is lower.
However, at the moment when I want to run the simulation, it throws an error saying:
Error processing expression 'Reaction Rate'.
The expression is invalid because:
Shear Rate is not available for use in this term
I previously had a similar problem with Shear dependent kinematic diffusivity and solved them using a ccl with RULES modified.
I was wondering if I can do the same here, like this:
RULES:
PARAMETER: Reaction Rate
Dependency List = ANY
END
END
I would appreciate any comment on that. Thanks a lot.
cardioCFD is offline   Reply With Quote
Old   December 19, 2017, 14:45
Opaque will become famous soon enough
Sure that should work if the requested variables is a valid ANSYS CFX name.
I think you are interested in the "Shear Strain Rate" though.
Opaque is offline   Reply With Quote
How can we get chemical reaction rate Gespenster Main CFD Forum 0 March 31, 2016 10:37
reaction rate Benfa CFX 0 January 22, 2013 13:58
Chemical reaction using Eddy Dissipation Model in FLUENT hyperflow FLUENT 5 June 11, 2012 04:54
CFX5.7 - chemical reaction problem... H.L. CFX 4 March 25, 2009 10:33
How to plot chemical reaction rate? Julie Polyakh Siemens 2 May 5, 2004 03:26
