December 19, 2017, 02:37 |
Shear rate dependent chemical reaction rates
Rep Power: 8 |
Hello
I am trying to define some reactions with shear rate dependent rates in CFX, i.e, reaction rates are higher when/where shear rate is lower. However, at the moment when I want to run the simulation, it throws an error saying: Error processing expression 'Reaction Rate'. The expression is invalid because: Shear Rate is not available for use in this term I previously had a similar problem with Shear dependent kinematic diffusivity and solved them using a ccl with RULES modified. I was wondering if I can do the same here, like this: RULES: PARAMETER: Reaction Rate Dependency List = ANY END END I would appreciate any comment on that. Thanks a lot. |
December 19, 2017, 14:45 |
Rep Power: 32 |
Sure that should work if the requested variables is a valid ANSYS CFX name.
I think you are interested in the "Shear Strain Rate" though. |
How can we get chemical reaction rate | Gespenster | Main CFD Forum | 0 | March 31, 2016 10:37 |
reaction rate | Benfa | CFX | 0 | January 22, 2013 13:58 |
Chemical reaction using Eddy Dissipation Model in FLUENT | hyperflow | FLUENT | 5 | June 11, 2012 04:54 |
CFX5.7 - chemical reaction problem... | H.L. | CFX | 4 | March 25, 2009 10:33 |
How to plot chemical reaction rate? | Julie Polyakh | Siemens | 2 | May 5, 2004 03:26 |
