How to create an average of an average?
Old   February 8, 2018, 13:52
Default How to create an average of an average?
Guille1811 is on a distinguished road
Im running a transient simulation of 300 seconds. For the thread purposes, lets say the simulation is just a giant cube of air with heat exchange. My coordinate system is so that Y is the vertical axis, and X and Z the horizontal axises.
I need to get the value of the average temperature along the line [z=a,z=b] located at plane X=0 and at height y=1 [mt], along all the simulation. In other words, get the average temperature across that line each second, and then average all those 300 values.
What could be a good/efficient way of doing this?
PD: no extreme precision is needed for the results nor the method.
Guille1811 is offline   Reply With Quote
Old   February 8, 2018, 18:38
This should be reasonably straight forward in CFD-Post. Use a session file to automate the generation of the line and line averaged temperatures. Then you could use the session file to put them all in a spreadsheet tab and average them there, or if that does not work export it and use an external package like matlab/python/excel/whatever to average them all.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   February 9, 2018, 18:34
Yeah the thing i forgot to mention is that the lenght of the line, ie the value of "b" is a result of the simulation deduced by doing some analisis in cfx post, so i donīt know it before hand. Because of this, doing a session file for that line lenght doesnt seem possible.
Back to the original problem, basically what i need is, given a manually created line in cfx post, get an excel or txt with 2 columns: one being the average temperature of that line in that given time or timestep, and the other column being the corresponding time or timestep.
With function calculator for average temp on that line this could theoretically be done manually, but i have to do this for 20 simulations, 300 seconds each so this is not really an option...
Old   February 10, 2018, 06:12
Why don't you include the generation of the line in the CFD-Post session file?
? That is exactly the situation where you would use a session file. If you are doing the same thing on lots of simulations over lots of time steps a session file can do this.
[ICEM] How can I create prism mesh for a 3D domain surrounded by a torus? lzgwhy ANSYS Meshing & Geometry 5 May 18, 2017 17:10
MRFSimpleFOAM goes divergenced! renyun0511 OpenFOAM Running, Solving & CFD 0 November 19, 2009 02:11
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
