February 11, 2018, 05:13 |
Supersonic flow
bhargav
I am doing CFD of turbomachine operating in supersonic flow in absolute frame. I am using CFx 17.1
Solver : k-w I have set reference pressure as 0 Bar Specified inlet conditions total temperature in stationary frame: 300 K total Pressure in stationary frame : 101325 pa And inlet velocity : 500m/s Outlet : I left it as supersonic (Is it good approach?) My fluid domain is small so I kept outlet as supersonic. Length of inlet and outlet domain is approx 320 mm. But I can see that velocity in result file is unbelievable and at inlet is of order of 3000 m/s !!! I have uploaded velocity contours, mach number contours, monitor of velocity during run at inlet (this velocity is area average over inlet) and residuals. Please....Can somebody help me What I am doing wrong here? Thank you so much. velocity as monitor point.jpg rsidual.jpg velocity.jpg mach number.jpg |
February 11, 2018, 18:30 |
Gert-Jan
Rep Power: 27 |
Step 1: Using Bernouilli-equation, calculate the static pressure on the inlet based on the conditions you provided. Then you'll see what is going wrong.
Step 2: Change it into something realistic. |
Species Transport Convergence trouble in Supersonic Flow | BrianF16 | FLUENT | 0 | February 28, 2017 12:18 |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech | enriccasas | FLUENT | 1 | August 21, 2013 06:43 |
Producing a supersonic flow in a constant diameter cylinder | clgs.1903 | FLUENT | 12 | May 24, 2012 13:41 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
