remote user of CFX4
Old   September 4, 2003, 02:21
Default remote user of CFX4
John
Hi, I am a new user of CFX4 and running CFX4 in a remote sever by using xwin32. The problem is that some forms can not completely shown on the screen, and I can not find roll bar or something to find the missing part of forms. Someone has the same experience? thanks
Old   September 4, 2003, 12:25
Default Re: remote user of CFX4
xxx
Is your screen large enough, I have seen this problem on 17" monitors. If this is the case I think you can adjust CFX to small screens.
Old   September 5, 2003, 05:23
CFX 4.3 users
Yes, I had a problem before specially with cfx-build. In build there is an option for small screen layout, so you can turn this on and everything will be fine. The other option is to change your monitor to a bigger one.
good luck
cfx4.3 user
Old   September 6, 2003, 23:40
John
Old   September 6, 2003, 23:45
John
Thanks for your information, but i can't find this option. where is it?
Old   September 7, 2003, 18:20
Johnson
Try to adjust your screen display property to 1280 by 1024 pixels. The problem may be solved
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 18:37
Please help cannot start lamboot hsieh OpenFOAM Installation 8 May 24, 2007 14:44
Job Scheduler for parallel processing kumar2 OpenFOAM Running, Solving & CFD 10 March 8, 2006 06:09
Best Code for User Fortran worth Main CFD Forum 4 November 14, 2003 10:21
CFX4: How to write user data to dump file? Min-Hua Wang CFX 3 July 17, 2003 20:49
