Adaptive Timestepping by using the acoustic Courant Number |
February 3, 2020, 08:02 |
Patrick
Rep Power: 6 |
i want to use the acoustic Courant Number for transient simulations, becuase i invastigate the sound propagation in pipes. I use the option adaptive time step with Max. Courant Number, but Ansys CFX uses the "normal Courant Number". I read in the Ansys CFX Theory Guide, that it is also possible to use the acoustic Courant Number (1.1.3.15, page 22): "The timestep may be chosen adaptively based on a Courant number condition (for example, to reachUnfortunaly, i can't find this option in the expert parameters. Can anyone please help me? Or does anysone know how to use the acoustic Courant Number in transient simulations? Greetings |
February 3, 2020, 16:17 |
Rep Power: 143 |
That expert parameter might not be in the GUI but you can set it using the command interface.
February 3, 2020, 16:36 |
Patrick
Rep Power: 6 |
Thank you! I never worked with the command interface before. How can i adress this parameter?
Is there any good Tutorial or something else which explains the use of the command interface? |
February 3, 2020, 16:46 |
Rep Power: 143 |
The easiest way is to:
* Insert an expert parameter (any expert parameter, it does not matter which) using the GUI * Right click on the expert parameter and select Edit in Command Editor * Replace the expert parameter you just generated with the one you want to add. * Click Process for it to process it and add it to the simulation.
February 9, 2020, 10:40 |
Patrick
Rep Power: 6 |
Thanks, it works!
acoustics, cfl number, courant number, time stepping |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Courant Number | waseeqsiddiqui | FLUENT | 3 | December 27, 2018 10:43 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
