Turbulence Models
Old   May 23, 2018, 03:49
Default Turbulence Models
Pedro Oliveira
oliveira1820 is on a distinguished road
Hello to you all again
In my system I have a water cooling system with 0,2 l/s where the water receives the heat from the solids around, which gets to "turbulent" velocities. (Reynolds number).
And a container with heated water which evaporates and gets really fast and hot.
IŽm tryind to decide wich turbulence models should I use for each situatuion and I canŽt get any conclusion. Do you have any hint which one fits better each situation in particular?
Best regards and thanks!!
oliveira1820 is offline   Reply With Quote
Old   May 23, 2018, 05:15
urosgrivc
urosgrivc is on a distinguished road
personaly I would use SST model for the firs case, beacouse you have heat transfer so you need acurate near wall modeling and because it combines omega and epsilon models with 2 blending functions. You can also complicate and add additional 2 equations for (transitional turbulence) intermitency and rethetat, so the flow can be laminar and turbulent (laminar usualy in the proximity of the wals)
For the second case I am not sure as i dont have experience with evaporation in cfx
urosgrivc is offline   Reply With Quote
Old   May 23, 2018, 05:16
siw
Stuart
siw will become famous soon enough
Shear Stress Transport (SST) with the default automatic wall treatment is a good place to start for RANS/URANS simulations. Only once you see the results can you judge if another model should be used instead or if you need to go with a RSM or scale-resolving method.
siw is offline   Reply With Quote
Old   May 23, 2018, 05:25
Gert-Jan
Gert-Jan will become famous soon enough
SST is my working horse in these cases.
Make sure Y+ is around 1 where Prandtl is high (approx 7 at cooling side?).
Gert-Jan is offline   Reply With Quote
Old   May 24, 2018, 02:06
Pedro Oliveira
I will use SST and see if I got convergence problems and if it doesnŽt corresponds to the experimetnal values IŽl try another.
Thank you very much guys!!!! Good work to you all
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 16:42
Adding turbulence models to (reacting)TwoPhaseEulerFoam lavdwall OpenFOAM Running, Solving & CFD 0 February 3, 2017 04:04
y+ range for turbulence models babri FLUENT 1 August 30, 2016 18:39
Zero Equation Turbulence models stefan.gracik OpenFOAM Programming & Development 3 April 17, 2013 15:12
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
