Rotating disk surfaces mesh
Old   March 9, 2004, 10:51
Default Rotating disk surfaces mesh
Francisco A Duque
Hi there,
I am trying to adapt a mesh to investigate how the flow is behaving in the cavity between the static disc and the rotating disc, i attached picture on (http://www.bath.ac.uk/~en9fad/rig/ri...ee_section.jpg), i understand i have to set individual meshes to each part; the rotating disc section (http://www.bath.ac.uk/~en9fad/rig/rot_disc_section.jpg), and the static section (http://www.bath.ac.uk/~en9fad/rig/st...sc_section.jpg), can anyone recommend me a type of mesh (radial to be possible) that works fine with this sort of geometry?
I am supossed to use CFX to investigate investigates the flow quality and Heat Transfer inside and around the receiving cooling holes.
Thanks in advance for any suggestions, i'm kind of new with CFX and no one at my university department knows about CFX.
Kind Regards
Francisco A Duque University of Bath
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] problemes modelling surfaces with snappyhexmesh gija79 OpenFOAM Meshing & Mesh Conversion 5 June 30, 2010 13:50
mesh without surfaces mrestrepo30 FLUENT 0 January 28, 2009 09:48
Conduction in rotating mesh Niels Linnemann FLUENT 0 May 4, 2007 08:13
Points on surfaces in a rotating mesh Martin FLUENT 0 August 22, 2000 13:36
