Impact simulation of container filled with fluid |
April 21, 2004, 13:53 |
I want to simulate the impact of a container filled with fluid when drop it from 2-m height by ANSYS. Because I am a newcomer in this field. So I have to ask some questions before run this problem.
1. Are the FLUID80 and SHELL63 elements appropriate for this problem? If not what elements are? 2. How to estimate the period of impact and the corresponding force as a function of time? 3. Is specifying displacement on some nodes necessary? If it is, where should be imposed? 4. What is the time step used in simulation? Is there anything I forget? Thanks in advance. |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
Negative Pressure In Fluid Simulation | pzr1988 | Main CFD Forum | 2 | February 26, 2011 01:28 |
Simulation of fluid flow through nozzles | Spiegel | Main CFD Forum | 3 | May 10, 2001 03:30 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 20:33 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 11:28 |
