centrifugal compressor torque negative - using cfx for simulation
Old   July 2, 2018, 05:45
Default centrifugal compressor torque negative - using cfx for simulation
limlibin
deii is on a distinguished road
Hi everyone,
I had setting
Inlet: Total Temperature: 300K; Total Pressure:1atm
Outlet: Static Pressure 1.9atm
Rotational Speed: -60000rpm
I had found that my torque is negative. What condition should i setting of exchange?
deii is offline   Reply With Quote
Old   July 2, 2018, 07:06
Make sure you understand the negative torque - what axis is it defined from? Negative torque could mean in the direction of rotation or against the direction of rotation depending on the definition.
Assuming it is in the same direction as the direction of rotation: Then the rotor wants to run at a faster speed and is trying to accelerate. The steady state speed will be faster than the speed you simulated.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
CFX Pre Domains for centrifugal pump MechKim CFX 1 September 24, 2012 08:06
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
