[Sponsors] | |||||
Zese
Rep Power: 14 ![]() |
Hi everyone
would you please help me about my outlet boundary condition at cfx software? I want to allocate zero gradient boundary condition at the outlet but I dont know how. thanks in advance |
Maxim
you should find that in the manual/help easily. Define Boundary Type, then go to the Boundary Details tab and select as Turbulence Option "Zero Gradient" in the drop-down menu. |
Zese
thanks Maxim but I am modeling a laminar swirl flow. I am not sure whether zero gradient condition is possible or not? second, for zero gradient condition should I consider my outlet as an opening condition?
Rep Power: 34 ![]() |
As the first response missed your expectations, it would be best if more information is provided
So far we know your flow is laminar; however, it is not clear if it is compressible, or incompressible, nor if you are modeling heat transfer or not. Single material, or multicomponents material, etc. Just a reminder on boundary conditions: They are not independent of each other. For example, flow in a pipe with mass flow inlet BC cannot be combined with Zero Gradient for velocity at the outlet. It is an ill-posed problem. Hope the above helps, |
#5 | |
Zese
I am going to simulate a swirl laminar flow in a pipe. my flow is incompressible and at the inlet I have 16 blades to make swirl an my inlet boundary condition is based on velocity inlet. it is single phase without solving heat transfer equations.at the outlet, I want to consider zero gradient boundary condition but I dont know how. thanks in advance Last edited by zese; July 13, 2018 at 18:43. |
Gert-Jan
Rep Power: 29 ![]() |
Could you please explain why you want zero gradient at the outlet? Because that is an uncommon boundary condition.
In fact you want flow through your outlet in strict normal direction. I remember from my first CFD classes in 1996 that the ancient software called Sepran allowed me to do this. However the results were very wierd. The pressure field required to obtain this prescribed normal outlflow was completely unrealistic. I can't imagine that you want something like this. So, please explain in detail why you want this. It looks like a X-Y-problem to me. |
#7 | |
Zese
I have two reason to do that First, I want to validate my study with an article written in 2001 that the author has set zero gradient condition at the outlet. In addition, Based on the experimental study the outlet boundary condition has not been represented in the paper. For example I dont have any idea about the pressure in the outlet. Once I tried with mass flow rate boundary condition with this idea that mass at the outlet and inlet is similar based on continuity equation but it didnt give good results. I wanted to try convective boundary condition but it was very difficult and studying manual didnt help me. |
Gert-Jan
As far as I know it it not possible to enforce zero gradient at the outlet. You can set normal speed (=uniform). Maybe better: specify the Cartesian components. In this way you might get pretty far. Then you are really prescribing what is happening at the outlet.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
| CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
| Boundary condition. How to get the normal gradient of the patchField U | Sylv | OpenFOAM Programming & Development | 1 | April 21, 2015 09:29 |
| several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 06:09 |
| Calculated gradient boundary condition similar to gammaContactAngle | adona058 | OpenFOAM Running, Solving & CFD | 0 | September 26, 2007 16:23 |
