July 18, 2018, 09:08 |
Best Turbulence model for Wind turbine
Hi
I am doing a transient rotor simulation of a horizontal axis wind turbine and I want to know which turbulence model is good for this simulation and which is commonly used by the experts ? |
July 18, 2018, 19:54 |
Rep Power: 143 |
Use the SST model for everything unless you have a good reason to know it will not work. That is the general advice. And SST works especially well on blade flows so it is definitely the one to use for your case.
NEW turbulence TRANSITIONAL model | giammy92 | OpenFOAM | 3 | June 30, 2016 09:47 |
Turbulence model for two phase incompressible flow | SailorLiu | OpenFOAM Running, Solving & CFD | 2 | April 4, 2016 07:53 |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
