About Icem cfd4.cfx
Old   June 21, 2004, 09:16
Default About Icem cfd4.cfx
amphibian
I use Icem cfd4.cfx to bulid geometry and mesh. How can I import the mesh to cfx5.7? Thanks!
Old   June 21, 2004, 18:15
Default Re: About Icem cfd4.cfx
derrek
Go to output and select cfx5 as the solver. You can give the file a name when prompted. In CFX Pre, choose ICEM as the input and search for the file.
Derrek
Old   June 22, 2004, 05:38
amphibian
But the cfxpre has error as your mehtod
Old   June 30, 2004, 16:48
KKA
hey buddy
those steps are correct. if the problem still persit, then make sure that everything is all right from the ICEM. The domain is probably set. During the export to CFX, make sure that you select appropriate version of the CFX5. Check your version and then select it but if you using CFX5.7 then just select 5.5 or later!!!
all the best!!
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
[ICEM] complex 2D meshing on ICEM kassab ANSYS Meshing & Geometry 26 April 14, 2014 21:02
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
