Starting a URANS computation from RANS result file |
August 30, 2018, 03:38 |
Rep Power: 14 |
Hi
I am trying to start a case with transient simulation (URANS) which ran for 1000 Iterations in RANS and I have the result file. From this I want to start my URANS simulation. Can someone tell me where I should give this RANS result file as input ? I have this job Submission file where there is a command line for CFX Arguments CFXARGS = "-def filename.def -ccl fileneame.ccl -double -size-mms 2.0" Should I insert the result file here as well ? Since I give the result file from RANS as input I dont have to initialize the URANS domain right ? Kindly let me know what is the process. |
August 30, 2018, 03:51 |
Lance
Rep Power: 22 |
If your result file is called resultfile.res then add the following arguments (see manual)
-initial-file resultfile.res or -continue-from-file resultfile.res no need for initialization if you use a .res or .trn file as initial values. |
August 30, 2018, 05:31 |
Rep Power: 14 |
Perfect Thanks a lot
August 30, 2018, 06:29 |
Rep Power: 143 |
For future reference: For just about any command line tool if you go "<executable> -help" it will list all the available options for the tool.
Alternately, in the CFX documentation there is a section on command line tools which describes all the options with additional detail.
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
