August 10, 2018, 04:15 |
Constant P-Mass Flow Residuum
Rep Power: 7 |
I would like to understand, why my P-Mass Flow criterion for the outer fluid not converge. I built a heat flow model with a hot tube and a surrounding air. The hot tube model consist of two materials. An inner ring made from copper and an outer ring made from steel. Inside the tube is a stream of hot air with 600°C. The hot tube is enveloped by not moving air with 15°C. The boundary condition of surrounding air is an opening, with opening pressure of 0 atm, because I don't know in which direction the air flows. Additionally there is Buoyancy Model activated, because I want to see the nature convection. It would be very nice, if somebody could help me, because I want to understand what happens here. Best regards Paul |
August 10, 2018, 06:45 |
Rep Power: 143 |
Have you read the FAQ on this? https://www.cfd-online.com/Wiki/Ansy...gence_criteria
August 13, 2018, 06:39 |
Gert-Jan
Rep Power: 27 |
Forget Residuals. First focus at the mass, energy and momentum imbalances. Create a graph in the solver manager where you plot these. How do these graphs look? These should all go to zero. After that, look at residuals again.
Possibly the mass and energy imbalances are not close to zero due to an ill posed problem with openings. Also, since you included natural convection, your solution might become transient. Then convergences might be troublesome anyway. |
August 13, 2018, 07:23 |
Rep Power: 143 |
I do not agree that you should forget the residuals. For most simulations they are the best estimate of solution accuracy as it is the accuracy of the linear solution to the non-linear equations. Imbalances are global balances which are useful in some cases but to only use them always is not recommended.
August 13, 2018, 08:22 |
Gert-Jan
Rep Power: 27 |
Maybe I should reformulate my quote and skip the word "Forget". What I meant is:
- first look at imbalances. - then look at residuals. It is possible to obtain a CFD solution with low residuals which make you think the solution is correct, but then still, the imbalances are way off. And as long 'in' is not equal to 'out' (for any equation), any solution is basically wrong. Bottomline: residuals are only useful as convergence criterium if the imbalances are close to zero. Last edited by Gert-Jan; August 14, 2018 at 03:13. |
August 13, 2018, 19:21 |
Rep Power: 143 |
I don't understand why you think the imbalances are more important than the residuals for general simulation.
If you use the imbalances as your convergence criteria, the internal flow detail could be completely wrong, but if the (flow in) = (flow out) then the imbalances will say it is converged. The residuals tell you how accurately the equations are solved over the whole domain, so they give the best picture of the overall simulation accuracy. There are a small proportion of flows where global balances are also important and residuals don't capture this well, with CHT simulations being a key example. This is why the residuals are the default convergence criteria, and imbalances are optional.
August 14, 2018, 03:58 |
Gert-Jan
Rep Power: 27 |
I don't use imbalances alone for judging convergence. I neither use residuals alone. I use them both. And I think everyone should use both.
As you mention it is possible to obtain a solution with low imbalances but with high residuals. I totally agree. But the other way is also very well possible. Especially if you stick to the default convergence criteria of 1e-4. I have had plenty examples where the flow seems converged based on residuals, but where the solution was not in balance. This applies especially for calculations including energy (CHT), scalar and mass fractions. And since these are coupled with mass and momentum......... Therefore I always look at imbalances first. Then I am sure that what goes in equals what goes out. So, I have a global developed field of velocity, temperature, mass fraction, etc. If that is satisfied, then I focus on the residuals to obtain a local converged solution. Moreover, for that I add a third level: I use multiple monitoring points in my domain where I monitor multiple variables. And if these provide me flat liners. Then I have a converged solution. Sometimes I can only get this thrid level satisfied with resduals lower than 1e-6! At least, if CFX can find a stable solution. Mostly transient effects come into play. So then residuals go up again and the variables start to wiggle. Bottomline 1: I think there is too much focus on residuals alone. In general, one should add 1 or 2 levels in quality control. Bottomline 2: This is one of the reasons why I prefer to use CFX over Fluent. The CFX-solver manager facilitates monitoring, crucial for quality control. In fluent, monitoring is a hassle, although things have improved lately. But lets go back to the initial question: Paul: - How does your geometry look like? Can you share a picture? - What about the opening? - How much flow goes in and how much goes out? - What about the energy imbalance? Last edited by Gert-Jan; August 17, 2018 at 18:59. |
August 14, 2018, 09:01 |
Rep Power: 7 |
Hey Gert-Jan and ghorrocks,
thank you for your advices. I made a plot with the imbalances. The mass imbalance doesn’t look good. It oscillates between 0% und 100%. The energy imbalance looks quite good. I uploaded my geometry. All three sides are openings, so I don’t have any Inlet or Outlet. That’s why I don’t know what’s going in and out. I hoped, that is calculated automatically with the boundary condition "opening". I also simulated the model without the buoyancy-model, but it’s actually the same result like before. That’s why I don’t think, that these results coming from transient processes. Opening: - Flow regime: Subsonic - Mass and Momentum Option: Opening Pres. And Dim Rel. Pressure: 0 atm - Flow Direction: Normal to Boundary Condition - Turbulence: Medium (Intensity = 5%) - Heat Transfer: Option: Opening Temperature Opening Temperature: 15°C - Thermal Radiation: Local Temperature geometry: all imbalances: energy imbalance: Best regards Paul |
August 14, 2018, 12:24 |
#9 |
Philipp Wiedemer
Rep Power: 9 |
Wouldn't it be advisable to look for max-residuals as well to get an idea if it is more of a local or global convergence issue? In a second step i would view the residuals in post to see which regions are making you trouble.
Why is it just the 4th step in the FAQ? It is alot faster to check compared to running the simulation with different timesteps, advection schemes, etc. and those are even maybe just hiding the problem of wrong physics/bad mesh instead of solving them. No critic here, just a genuine question |
August 14, 2018, 16:39 |
#10 |
Gert-Jan
Rep Power: 27 |
An opening is an inlet and an outlet. Flow can go in and out, depending on the local conditions in your domain.
The imbalance is based on the flow going into the domain, if I am correct. So if you created 1 opening containing all three sides, then only a small mass will go in or will go out (round off error), resulting in the flip-flop behaviour of the imbalances. My advice would be to: - create a larger surrounding volume - create an separate opening at the bottom - create an separate opening at the top - apply symmetry at the sides, at least as first guess. You can always change it later on. Then probably the flip-flop behaviour will dissappear. More questions: - How is your geometry oriented to gravity? Parallel to the tube? Or in cross flow? - How does the velocity field in the surrounding air look like? - How do you model the steam? Is it a solid with a fixed temperature? Or do you also model the flow inside the tube? |
August 15, 2018, 18:34 |
#11 | |
Rep Power: 143 |
August 17, 2018, 14:37 |
#12 |
Philipp Wiedemer
Rep Power: 9 |
August 17, 2018, 18:57 |
#13 |
Gert-Jan
Rep Power: 27 |
I also added a section regarding the imbalances (my favourite topic :-) ).
Please read it and edit if necessary......... |
August 19, 2018, 05:38 |
#14 |
Rep Power: 143 |
Thanks, much appreciated. The wider range of people who contribute to the FAQs the better.
August 23, 2018, 11:05 |
#15 |
Rep Power: 7 |
Hey,
Thanks a lot again for your advices. I didn't find time to check the new settings. Now I triedyou’re your advices. It is now much better. There is just a kind of oscillation, which is maybe because of the natural convection. The imbalances looking quite good. So I think there is an improvement. To your questions: - the gravity is oriented in cross flow - i attached a picture of the velocity - the steam in the inner pipe has a fixed temperature, but i model the fluid as well. So it isn't just a hot solid. Convergence: Imbalances: Field of velocity: Best regards Paul |
August 23, 2018, 19:02 |
#16 |
Rep Power: 143 |
Your convergence is pretty bad. I do not agree with Gert-Jan's focus on imbalances, I think he underestimates the importance of the residual. In your case the residuals are bad and the imbalances are good, so this is exactly the sort of case where not paying enough attention to the residuals will cause problems.
It is starting to look like your simulation is transient and will require a transient simulation to get good convergence. And please post images directly on the forum, not on 3rd party sites. Instructions on how to do it are here: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F
August 24, 2018, 05:04 |
#17 |
Gert-Jan
Rep Power: 27 |
Paul,
imbalances are better indedd. So what goes in equals what goes out. But that is only half the story. Your residuals are very bad, as Glenn mentioned. And both should be ok. So you should take many more iterations to get a decent result. But lets take a step back and look at your velocity field. - What is the range in velocities? - What does this mean? - Is it realistic and is it what you would expect? - What are your boundary conditions? Are they realistic? Don't think so.......... |
August 30, 2018, 09:25 |
#18 |
Rep Power: 7 |
Hey,
so I put more iterations on the solver and yes now it's going better. I mean there are still some transient processes, but all in all I get, what I want. The oscillating part must be there, because of the buoyancy model, because in the disabled mode there is no oscillation. - The inner flow, has a mass flow of 0.1 kg/s - There is no special model for the inner flow - I would suggest some kind of transient processes because of the nature convection, maybe it is oscillating because of steady solution - The boundaries are realistic best regards Paul |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 00:09 |
Mass flow rate of phase in post | mat_cfd | CFX | 0 | September 3, 2013 07:55 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 04:18 |
