ERROR #001100279
Old   September 29, 2004, 13:38
Default ERROR #001100279
Anurag
I'm getting an error in solving a porous media (ERROR #001100279 has occurred in subroutine ErrAction. Message: NAME MOD: error finding variable "SPHEATP". What is this variable?
I'm modeling a porous media (composite cylinder in which, both inner and outer cylinder acts as porous media with different properties). Both are defined as domain & then sub-domain to assign different porous resistance. I am using multi-component model since fluid is injected into the domain. I am using CFX 5.7
Thanks in advance. Anurag
Old   September 29, 2004, 21:37
Default Re: ERROR #001100279
Juan Carlos
Dear Anurag,
SPHEATP is the Specific Heat Capacity at Constant Pressure within CFX-5.7. Since it is missing the fluid/material part, something must have gone wrong during the property calculation.
I advice you to contact your CFX representative/helpdesk and pass your definition file (.def) to them for quicker response. It could be a setup error or that you have found a blatant bug.
Juan Carlos
Old   September 30, 2004, 09:53
salman
hi, i am just conserned, from where i can find .....CFX representative/helpdesk? can you tell me please ..
regards,
Salman
Old   September 30, 2004, 16:41
Anurag
Dear Carlos, thanks for ur reply. the case i'm dealing is "Isothermal". However, when i changed Heat transfer model option to "none", problem was fixed. I have little doubt about difference between the option "Isothermal" and "none".
Anurag
Old   September 30, 2004, 18:24
Your CFX rep is the people you paid your license money from. Talk to whoever is responsible for license purchasing at your establishment.
