how to create surface mesh in icem5?
Old   October 3, 2004, 05:45
Default how to create surface mesh in icem5?
Pete
Hi all,
Just wonder how can we create the tetra surface mesh in ICEM 5 and then use it to create the volume mesh? Like the method used in Build. Can't access Build right now. The automatic tetra mesh generator in ICEM5 gives me a rather crappy surface mesh....Any idea is welcomed.
Thanks, Pete
Old   October 3, 2004, 06:41
Default Re: how to create surface mesh in icem5?
deLuther
Just use Meshing->Surface mesh->Patch independent mesh. Smooth surface mesh accordingly and then use Tetra->From triangle surface mesh. (Expressed in terms of old Interface of ICEM 5.0). In new interface this can be done in similar way.
Old   October 4, 2004, 01:11
Pete
Thanks,deLuther. It works well but can you please explain briefly what's the meaning of "patch independent" in ICEM5? I notice that there're 3 options to create surface mesh.
Old   October 4, 2004, 02:42
deLuther
Patch independent means that first of all tetra mesh created in usual way, but then tetras are deleted and surface mesh leaved alone... Patch Dependent means that ICEM creates LOOPs(or user creates it manually) and meshes them using QUAD mesher(also you can choose triangles). This way not always make what you want... Third way is creating surface mesh in HEXA, converting mesh to triangles and meshing from surface mesh...
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Help ! Create surface for sliding mesh. YH Tan FLUENT 0 October 5, 2008 04:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
