How to initialize a simulation from RANS to URANS
Old   September 26, 2018, 03:51
Default How to initialize a simulation from RANS to URANS
AS_Aero is on a distinguished road
Hi
I am trying to restart a simulation from RANS to URANS
I changed my physics model for the .def file and then in that what should I do with the intialization tab for the domains ?
Then I have the RANS results as .res file.
I know somewhere I have to upload it, but I am running it in cluster so I have a script for it there I normally to restart the case I give
-def flename.def -ini filename.res -ccl filename.ccl
so will this way it works for RANS to URANS as well ? If yes what about the intialization tab in the CFX Pre ?
AS_Aero is offline   Reply With Quote
Old   September 26, 2018, 04:39
Gert-Jan
Gert-Jan will become famous soon enough
Sure it will work.
In Pre, you only get a warning that a transient run requires an initial guess. Therefore it would like you to set some values. But you can safely ignore this. Pre doesn't know yet that you have the best initial guess available: your steady state run.
Gert-Jan is offline   Reply With Quote
Old   September 26, 2018, 04:43
Perfect Gert Jan !!
But lets say I want to run an LES case with very refined mesh, in that case if I need to have an intial guess, I need to run the same fine mesh a RANS simulation and then only I can use it for the intialization right ? I cant use another coarse mesh results and use that to initialize the LES simulation ?
Old   September 26, 2018, 04:51
Gert-Jan
You can use any mesh you like for initialization. You can even interpolate a car on a ship, or a pump on your windmill. CFX doesn't care. You are in control, you should make a clever choice.
Please read the output file. There a lot of info is given on the interpolation/initialisation process. It will tell you if the volumes of the different meshes fit, how many nodes are on the same spot, etc, etc.
Old   September 26, 2018, 04:57
Thanks again. No I was just asking if its a good practise to do like that ? to use different mesh results for intialization of another simulation.
Old   September 26, 2018, 07:28
If the initial condition mesh is the same as the continuing mesh then you don't need to do interpolation and that is an advantage. But the interpolator is rarely a problem so do not get too concerned if your meshes are different.
What is more important is that the flow described in the initial conditions are actually representative of what you are trying to do.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Utility to initialize LES Simulation ScarFace OpenFOAM Pre-Processing 3 October 24, 2018 18:24
Transient RANS Simulation Bazinga Main CFD Forum 5 June 21, 2017 11:21
Simulation RANS Explode fredicenci OpenFOAM Running, Solving & CFD 4 May 23, 2017 13:29
Difference Between RANS And URANS Divyaprakash OpenFOAM Running, Solving & CFD 0 January 19, 2016 09:37
Simple question: Time-Dependent RANS vs URANS c.alanis Main CFD Forum 3 January 28, 2015 12:10
