ICEM Hexa - Deleting Empty Parts!!
Old   October 19, 2004, 10:20
Default ICEM Hexa - Deleting Empty Parts!!
James Date
Hi
Can someone tell me why I cannot delete empty parts when using ICEM Hexa.
I have deleted all of the un-necessary part geometry in my model and would like to clear the un-used part names.
However, ICEM will not let me do this!
If I just read in the .tin file the geometry without these parts is loaded. However, when I read the blocking in these parts names suddenly re-appear!
Any ideas guys.
James
Old   October 19, 2004, 12:04
Default Re: ICEM Hexa - Deleting Empty Parts!!
KKA
Hi James
I'm clear about what part you meant. But if you're talking about Families, then this is what happened.
Hexa always take the families defined at MED. Thus Families defined in MED will only be seen in HEXA. So if you remove or change family, and don't want it to appear then click on Edit in Display Menu. Then select delect Unused Families. That will refresh your family list. This new family list will show in HEXA irrespective what block file that you used.
But if remove a part in your block file, it has nothing to do with the Family name. Remember HEXA is only for Meshing and has nothing to do with the geometrical changes. Geometry(.tin) can be modified in MED before sending it to HEXA for meshing. In that case you might consider creating NEW Block files as oppose to using existing one.
All the best!!
Regards!!
Old   October 20, 2004, 00:30
deLuther
Maybe problem is that families was deleted but they again appears in hexa. I have such things many time. At current time I found that after deleting empty families you must save projects. Sometimes this operation not enough and then I save Boundary condition file and it helps...
Old   October 20, 2004, 11:11
James Date
Thanks guys.
I've worked out what to do:
1) You have to close the blocking file. 2) Delete the un-used parts. 3) Re-load the blocking file.
Thanks again
James
Old   December 23, 2004, 01:24
Default it's a bug in icem 5.0?
hyb
when move or rotate some obeject but forget to choose any object and then press apply button . the computer will never respond quickly and keep waitting for quite a long time.at that time i have to shutdown the programming and restart it again!
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 15:06
icem hexa mesh parts pb jaber CFX 5 July 8, 2009 03:59
icem hexa mesh parts pb jaber Main CFD Forum 2 July 7, 2009 15:30
[ICEM] icem hexa mesh parts pb jaber ANSYS Meshing & Geometry 3 July 5, 2009 06:23
icem hexa mesh parts pb jaber FLUENT 0 June 12, 2009 18:06
