October 24, 2004, 05:54 |
CFX 5.7 error by routine PEEKCS and MEMRR
Dear Sir:
I am simulating the gas-coal gasification process in the combustor, and my simulation case starts from coal_combustion.ccl (examples). I expand the chemical species in gas mixture and the volatiles componets to three components. Then, multi-step reaction is modified from Volatiles Oxygen WD1. Thus, 4 steps reactions are used. After CFX-Pre without any problem, I preceed to CFX-Solve, but one error occurs just during the outer iteration 1 , and I can't find any information in any document of CFX5. The errors is as follows: Your help is highly appreciated! regards, ================================================== ==================== OUTER LOOP ITERATION = 1 CPU SECONDS = 2.20E+00 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.00 | 7.3E-06 | 4.1E-05 | 3.5E+01 ok| | V-Mom | 0.00 | 7.2E-06 | 4.1E-05 | 3.6E+01 ok| | W-Mom | 0.00 | 2.6E-02 | 4.3E-01 | 1.2E-01 ok| | P-Mass | 0.00 | 6.5E-03 | 1.2E-01 | 12.1 8.5E-02 OK| +----------------------+------+---------+---------+------------------+ Details of error:- ---------------- Error detected by routine PEEKCS CDANAM = FL1 /BALLAST CRESLT = NONE +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The CFX-5 solver exited with return code 1. No results file has | | been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | The CFX-5 Solver has written a crash recovery file. This file has | | been saved as | | e:\cfd_cases\cfx5.7_cases\gasifier_ok2\gasifier_wa ng_016.res.err | | and may be an aid to diagnosing the problem or restarting the run. | | More details should be available in the solver output section of | | the output file. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | e:\cfd_cases\cfx5.7_cases\gasifier_ok2\gasifier_wa ng_016: | | | | mon | +--------------------------------------------------------------------+ This run of the CFX-5 Solver has finished. |
