Advice for fan cooling needed
Old   January 12, 2005, 18:57
Default Advice for fan cooling needed
CK
I am trying to simulate the cooling of a power supply by a fan. I just started using CFX hence I am having trouble to input the fan curve in order to obtain the proper volume flow rate through the fan. Can anyone give me some advices?
Thanks in advance,
CK
Old   January 17, 2005, 16:13
Default Re: Advice for fan cooling needed
Are you trying to model the fan using a momentum source?
Old   January 19, 2005, 23:00
CK
Hi Glenn, Yes I was planning to use a momentum source to simulate the fan. Is there a different approach?
CK
Old   January 20, 2005, 16:53
A momentum source is often the best method where you don't want to model flow in the fan itself. As for making the flow follow the fan operating curve, that can be implemented using a 1D CEL interpolation and some CEL expressions.
Other options besides momentum sources include: 1) modelling the fan in detail 2) if the upstream or downstream side of the fan is not important you can model the fan using a boundary condition with a specified mass flow rate or pressure.
Prism layer advice needed for steady state port flow case MaxCFM Main CFD Forum 1 October 1, 2009 09:26
Fluid dispersion into a free stream - Advice needed please LSF FLUENT 0 April 12, 2009 08:45
Hardware extension advice needed Luk CFX 7 February 2, 2009 18:05
advice needed! Filip Main CFD Forum 2 April 26, 2002 15:27
advice needed in solving linear system yf yap Main CFD Forum 5 February 5, 2001 00:21
