January 21, 2005, 14:30 |
CEL error in tutorial #20
In tutorial 20, I am getting error while defining boundary condition 'ball". In "Mesh Motion" of boundary detail tab when "displacement y component" is set to dBallNew, it gave following errors
Bad expression value 'dBallNew' detected in parameter 'Displacement Y Component' in object '/FLOW/DOMAIN:checkValve/BOUNDARY:ball/BOUNDARY CONDITIONS/MESH MOTION'. CEL error: Error in setting: "FFlow" via the expression: force_y()@Ball force_y()@: read successfully, and then error found at item: Ball syntax error Initially I created expressions individually. When it did not work i imported ValveFSI_expressions.ccl I got the same error in both cases. Has anyone got the same error? Please help me. Anurag |
January 21, 2005, 16:23 |
Re: CEL error in tutorial #20
At the CEL expression, Ball indicates a boundary condition. So the boundary condition has to have exactly that name, Ball (it is case sensitive). For what you wrote I would say that you named the boundary condition as ball (with small b), while in the CEL expression you have Ball (with a capital B). There is a bug in CFX-5.7 related with the moving mesh capability (it was fixed in CFX-5.7.1). So if you are using CFX-5.7 and after you have managed to solve you problem, you get this error in CFX-Solver: "The CFX-5 solver could not be started, or exited with return code 255: No results file has been created", take a look at: http://www.cfd-online.com/Forum/cfx.cgi?read=9065 , and to http://www.cfd-online.com/Forum/cfx.cgi?read=9072 . Good luck. Regards, Rui |
Tutorial for subcooled nucleate boiling | Asghari | FLUENT | 42 | December 10, 2018 11:42 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 09:41 |
