Transient run and real time
Old   April 6, 2005, 06:28
Default Transient run and real time
RK
HI;
Just 2 retard questions:
1) In the command file (20*1.0E-02) is applied for fixed time stepping, but the run stops (giving out dump files + output file) after 1st time step...anyone know why? (In case: convergence hasn't been achieved)
2) If above is resolved: how is it possible to write out data in USRTRN based on real time (e.g 0.05 s) rather than time steps. Would this be OK;
REALT= (KSTEP*DT)?
IF (REALT .EQ. 0.02) THEN ...
END IF
At present this doesn't seem to be working...
Thanks in advance...
RK
Old   April 6, 2005, 08:28
Default Re: Transient run and real time
Forrest
Your questions: (1) Did you set up the Maximum Number of Iterations under 'program control'? (2) If you use output options:
DUMP FILE OPTIONS
EACH TIME STEP
ALL VARIABLES
END
You should be able to get results for any time step
Hope this helps
Regards, Forrest
Old   April 6, 2005, 09:54
RK
Hi Forrest:
Thanks for you response but
(1) Yes, I have set up MAX ITERATIONS. But still no good...only one time step then it stops
(2) I understand what you are saying for the dump file options, but I wanted to write out information from usrtrn at specific time (say 0.1, 0.2, 0.3 secs..etc).
REALT=KTEP*DT
IF (REALT .EQ. 0.02) THEN BLAH... END IF
Any further suggestions...
Thanks again...
RK
Physical Reason for stability of Implicit Schemes? radhakrishnan Main CFD Forum 26 October 3, 2023 22:05
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 03:40
Transient time information Forrest CFX 4 October 24, 2003 03:57
