May 10, 2005, 06:03 |
CFXPost-Help!
In CFX-POST, I tried to plot some presuure contours, but the scale are so large they obscure the contours, how can I reduce the size of those scales or better yet turn them off.
May 10, 2005, 07:13 |
Re: CFXPost-Help!
I don't know exactly what you mean. But in CFX-Post you have 4 options for the range (is this what you mean by scale?) of the contour: Global, Local, User Specified and Value List. On the Labels tab you may chose if you want to show the contour numbers. On the Render tab you may check or uncheck the Draw Faces box and the Draw Lines box, on this last one you have the option to select Constant Colouring (and the colour you want). Regards, Rui |
May 10, 2005, 09:32 |
Re: CFXPost-Help!
Rui, Thanks, but what I mean is the font size on the scalss, they are so big compared to the contours, I like to turn 'em off or reduce.
May 10, 2005, 09:49 |
Re: CFXPost-Help!
you can change the font size in Default Legend in View Control
May 10, 2005, 10:06 |
Re: CFXPost-Help!
In CFX-5.7 and 5.7.1 Post, on the Objects tab open the View Control (click the + symbol) and you may uncheck the Default Legend box. You may also double click it to edit it, then select the Appearence tab and you have some options to change the legend display. To reduce the font size, reduce the value in the Text Height box.
In CFX-5.6 you can do the same things, but you'll find the Default Legend in the Object Selector box instead of the Objects tab. Regards, Rui |
May 10, 2005, 18:13 |
Re: CFXPost-Help!
Cheers ! Rui.
How to get rid of ANSYS logo from CFXpost etc | Kumar | CFX | 10 | July 12, 2016 01:17 |
Velocity profile in boundary layer in cfxpost | bennn | CFX | 9 | March 26, 2010 15:10 |
help on CfxPost | asder | CFX | 0 | August 20, 2008 18:13 |
Make line on curved boundary in CFXPost? | andy2O | CFX | 4 | March 20, 2008 12:50 |
CFXPost & Cylindrical CS | KG | CFX | 3 | November 11, 2002 09:39 |
