What is the meaning of stress free boundary condition? |
March 16, 2013, 21:11 |
Govindaraju
Rep Power: 17 |
Dear all
I have come across stress free boundary condition at the outlet in a pressure drop analysis in many journals ( Transient analysis). I have confused with 0 Pa setup at the outlet with stress free boundary condition. for stress free boundary condition, I assume that the initial condition pressure setup and outlet boundary condition must be the same. Please correct me if I am wrong. Thank you Regards Govind |
March 18, 2013, 10:26 |
OJ
Rep Power: 20 |
From what I understand, the stress-free boundary condition must be "shear-stress free" boundary condition which can be symmetry or free slip wall
Analogically, since three is no change in velocity perpendicular to the boundary (unlike wall where we have significant velocity gradient), the shear stress value should be zero/negligible. Though, you may want to confirm this with a bit of literature search. OJ |
March 19, 2013, 01:57 |
#3 | |
Govindaraju
Rep Power: 17 |
Thank you for your reply so, stress free boundary condition doesn't mean that outlet pressure equals to zero . Am I correct? I know the symmetry boundary condition where all the normal component should be zero. consider a pipe , how do you apply symmetry boundary condition at the outlet face? if so what does it mean? when we apply free slip boundary condition at the outlet face? Thank you Regards Govind Last edited by kmgraju; March 19, 2013 at 02:21. |
March 19, 2013, 04:31 |
Rep Power: 143 |
This question has been asked a few times on the forum. Do a search of the forum for more details. I recall the stress free BC is zero normal gradient at the outlet. CFX does not implement the outlet boundary exactly this way, read the documentation for what it does do. And implementing a zero stress BC is going to be difficult, and frankly why bother when the built in outlet boundary is better in many ways.
March 19, 2013, 04:41 |
#5 | |||
OJ
Rep Power: 20 |
Ref: Houseman, G. A. "Boundary Conditions and Efficient Solution Algorithms For the Potential Function Formulation of the 3‐D Viscous Flow Equations." Geophysical Journal International 100.1 (1990): 33-38. Quote:
OJ |
March 10, 2016, 15:44 |
#6 | |
Reviewer #2
Rep Power: 10 |
March 10, 2016, 17:17 |
#7 | |
Rep Power: 143 |
Didn't he answer your question?
August 11, 2017, 12:33 |
Reviewer #2
Rep Power: 10 |
August 12, 2017, 06:35 |
#9 |
Rep Power: 143 |
Have a think about what they mean mathematically - the answer is no. You can define the boundary to have, in general, either a prescribed value at the boundary or a prescribed gradient, but you can't define it to have both a prescribed value and gradient.
August 24, 2017, 11:06 |
#10 |
Reviewer #2
Rep Power: 10 |
Isn't setting up the reference value (for example pressure) is somewhat like a dirichlet boundary condition?
August 24, 2017, 18:17 |
#11 |
Rep Power: 143 |
No. It just offsets the entire pressure field. It has nothing to do with defining boundary conditions.
December 7, 2018, 06:52 |
Orr-Sommerfeld equation
#12 |
Wang Zhe
Rep Power: 11 |
The boundary condition for u_2 in the Orr-Sommerfeld equation is u_2=partial_y u_2 =0 at walls. Therefore, yes you can have both Dirichlet and Neumann boundary condition simultaneously.
December 7, 2018, 19:40 |
#13 |
Rep Power: 143 |
Good point. You are correct, the direct answer to the question is that yes, you can have both a Dirichlet and Neumann boundary condition in place simultaneously.
It gets a bit more complex in CFD because you have boundary conditions which need to be applied to both momentum and pressure equations simultaneously. So yes, you can apply Dirichlet and Neumann boundary conditions on, say, the momentum equation simultaneously, but what do you apply to the pressure equation? Also you need to ensure that all boundaries are mathematically well posed across the entire domain, with issues like how the pressure needs to be set somewhere and they cannot be all velocity boundaries in incompressible flow and so on. So while the answer you the question is yes, if you consider implementing it things get more complex as CFD is never simple
How to decide the boundary condition for free surface? | dut_thinker | Main CFD Forum | 5 | February 16, 2011 06:48 |
RIPPLE's free surface boundary condition | alongalong2 | Main CFD Forum | 4 | February 9, 2011 23:35 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 00:55 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
