CFX Frozen rotor interface
Old   December 9, 2018, 04:57
Default CFX Frozen rotor interface
saha2122 is on a distinguished road
Send a message via Yahoo to saha2122
Hi every body
I modeled 2 rotating solid with different angles, 30 and 90 degree using CFX.
The interface of those defined as frozen rotor. In the solver this error has occured:
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Zero divide |
| Message: |
| Stopped in routine FPX: C_FPX_HANDLER |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
what should I do??
I tried so finer mesh too, but dosnt work.
just by changing the frozen rotor to None or deleting the interface the error is omited!
Is there any body to help me?
by the way this model is part of a conjugate model that I try to solve the mentioned error first.
look forwad for your comments.
So many thanks.
saha2122 is offline   Reply With Quote
Old   December 9, 2018, 06:17
Did you get a floating point error before this? If so, FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 9, 2018, 07:33
hi ghorrocks
thanks for always soon replying.
all of the error is something that I presented in last post.
what should I do now?
Old   December 9, 2018, 17:32
The error is stating divide by zero error. So either you set it up wrong which results in divide by zero (so you have to fix your set up), or it is diverging and getting divide by zero (and the FAQ I linked to is what to do).
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 08:08
cfx pre frozen rotor maheshchamarti CFX 0 July 5, 2017 04:36
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
