Build a pipe with different layers
Old   June 8, 2005, 09:54
Default Build a pipe with different layers
Sun
Dear Colleagues
I am trying to simulate the heat transfer process in an insulated pipe. The pipe is used to transfer a hot water (85'C) between two points (100 m) and the outlet wall temperature is fixed at 10'C. The inner and outlet diameter for pipe are 50/60 mm while the insulator has 65 mm outlet diameter. Thermal conductivities for pipe and insulator are 35 and 2 kW/m.K.
I have used CFX 5.5 to build my case. However, I found it quite difficult to build a pipe with different layer.
Any help will be appreciated!
Note; I am a new user
Best Regards
Sun
Old   June 9, 2005, 07:50
Default Same problem
Xu
Hi
I have faced the same problem that I want to draw a pipe in CFX-Build???
Xu
Old   June 9, 2005, 18:33
Default Re: Same problem
Firstly, your version of CFX is very old. I recommend you update to the current version. Much nicer to use, much easier.
There are examples which describe the generation of multi-domain meshes in CFX-Build. Give them a try.
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
[snappyHexMesh] snappyHexMesh - layers in 3d pipe bifurcation nihil OpenFOAM Meshing & Mesh Conversion 13 April 9, 2013 08:32
Pipe Boundary Layers Kieran Hood Main CFD Forum 0 April 22, 2007 17:48
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
