How to calculate the Derivative of Density to Time |
December 31, 2018, 06:53 |
Zhiyuan Liu
Rep Power: 7 |
I have tried the inserting A.V method, but I faild.
Is there simpler method to complete it? |
December 31, 2018, 16:48 |
Rep Power: 143 |
Do you want to calculate it in solver time or post-processing?
Do you want the full variable field or an an average over the domain/boundary patch?
December 31, 2018, 22:48 |
#3 | |
Zhiyuan Liu
Rep Power: 7 |
Thank you for your reply. I have solved out this problem with time derivative operator. But I stiil want to know why the Trans_Loop trick does not work? There's a similar problem. Why the Trans_Loop trick does not work? No old time value obtained! My ANSYS is v18 and I found I need not to do the one iteration initialization A.V with Zero. Whether this trick has been delected in the new version? If it has been debugged, how can we store last iteration result? Thank you! Last edited by Saeef; January 1, 2019 at 02:52. |
January 2, 2019, 05:21 |
Rep Power: 143 |
The TRANS_LOOP thing is an undocumented feature, and therefore is highly unstable, not guaranteed to work and can give unreliable results. Use it at your own risk. If you report it does not work in your case - it does not surprise me.
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
