Pressure ratio calculation in a transient run |
February 20, 2019, 02:18 |
#41 | |
Rep Power: 14 |
By the time step sensitivity analysis you mean increaseing the number of time steps per a passing period and the solution should not change? |
February 20, 2019, 17:25 |
#42 |
Rep Power: 143 |
A sensitivity analysis is you change the input parameter (mesh size, convergence criteria, time step size) and you see if the outputs change by an amount you care about. Make sure your change to the inputs is big enough to be useful - halving the element edge length (results in 5-8 times more elements), halving time step size or x0.1 for convergence criteria are normal increments. And whether the output has converged or not depends on how accurate you want to be.
February 21, 2019, 06:50 |
#43 | |
Rep Power: 14 |
In the run folder, another file such as name_full.trn is saved. Should I change the .res file to .trn file when restarting a transient simulation? The default initialization option is “current solution data”. I there a need to change that? |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
transient pressure and temperature boundary condition profile inicialization | Aurora23 | FLUENT | 2 | April 21, 2015 16:01 |
Get the maximum and minimum pressure in the domain(In parallel calculation) | xh110120 | Fluent UDF and Scheme Programming | 4 | October 10, 2014 08:06 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
