Simulating Radial Inflow Turbine - Mass Flow Rate at Inlet not matching outlet
Old   March 8, 2019, 10:53
Default Simulating Radial Inflow Turbine - Mass Flow Rate at Inlet not matching outlet
MoBangi
mobangi12 is on a distinguished road
Hey, i am currently trying to simulate a radial inflow turbine using ansys cfx. I first meshed the rotor and stator in turbogrid. I setup 3 domains in cfx, S1 for the stator, R1 for the rotor and S2 for the outlet. My boundary conditions are total pressure at inlet, total temperature and static pressure at outlet. I have 2 interfaces, stage mixing between S1 and R1. Frozen Rotor between R1 and S2. Simulating real gas (R123) with RGP file. There is currently a difference of around 5% between the mass flow rate at the inlet and mass flow rate at the outlet. (~0.41kg/s inlet, ~0.43/0.44 kg/s outlet)R1.jpg
mobangi12 is offline   Reply With Quote
Old   March 8, 2019, 10:54
MoBangi
Had to cut out timesteps from 38-300 as the file was too largeOUTFILE.txt
Old   March 8, 2019, 14:06
Julian121 is on a distinguished road
Has the simulation fully converged?
Have you looked at the imbalances for all domains?
Julian121 is offline   Reply With Quote
Old   March 8, 2019, 14:52
MoBangi
Hey thanks for your reply, the solution was fully converged. I had a few that ran for 1000+ iterations with the same result. I have a theory that its something to do with the fact that i have 22 stator blades and 15 rotor blades. So for each rotor blade there are 22/15 stator blades. Not too sure though. And these ar my imbalances, they dont look too large.
| Normalised Imbalance Summary |
| Equation | Maximum Flow | Imbalance (%) |
| U-Mom-R1 | 9.8032E+01 | -0.0084 |
| V-Mom-R1 | 9.8032E+01 | -0.0023 |
| W-Mom-R1 | 9.8032E+01 | 0.0000 |
| P-Mass-R1 | 2.9154E-02 | 0.0032 |
| U-Mom-S2 | 9.8032E+01 | 0.0000 |
| V-Mom-S2 | 9.8032E+01 | 0.0000 |
| W-Mom-S2 | 9.8032E+01 | 0.0000 |
| P-Mass-S2 | 2.9154E-02 | 0.0001 |
| U-Mom-S1 | 9.8032E+01 | 0.0009 |
| V-Mom-S1 | 9.8032E+01 | -0.0008 |
| W-Mom-S1 | 9.8032E+01 | -0.0075 |
| P-Mass-S1 | 2.9154E-02 | -0.1077 |
| H-Energy-R1 | 1.2675E+04 | 0.0032 |
| H-Energy-S2 | 1.2675E+04 | 0.0000 |
| H-Energy-S1 | 1.2675E+04 | -0.1099 |
Wall Force and Moment Summary
Old   March 8, 2019, 15:06
MoBangi
Do i maybe need to model 3 nozzles and 2 rotors as opposed to my 1 nozzle and 1 rotor at the moment? Would this affect my solution?
Old   March 8, 2019, 15:17
Are you using appropriate expressions to evaluate mass flow at the inlet/outlet?
e.g. massFlow()@S1 Inlet*22
massFlow()@S2 Outlet*15
Old   March 8, 2019, 15:53
MoBangi
found a way to fix it
cfx, interface, mass flow, radial turbine, real gas model
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 05:58
Channel Flow with Constant Mass Flow Rate huzafa OpenFOAM Running, Solving & CFD 0 August 1, 2018 10:31
Specify mass flow rate for periodic boundary conditions in channel flow lion1990 OpenFOAM Running, Solving & CFD 1 July 9, 2018 17:46
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 10:09
