how to monitor free surface elevation vs time and wall height in CFX? |
March 5, 2019, 20:23 |
Aashi
Rep Power: 7 |
can anyone help me out to monitor the height of free surface during sloshing in cylindrical tank or sloshing wave height as a result of seismic excitation?
March 5, 2019, 23:00 |
Rep Power: 143 |
You need to define exactly what you mean by height of free surface. Average height over the whole domain? Average height over a boundary face? Height at a specific XY location (assuming gravity is in the Z axis)?
You can do any of these in CFD-Post (as long as you saved the timestep data) or Solver Manager (to track it during run time). You just need to define a mesh identifier (a volume, face or line) and then use volumeInte(volume fraction)@VOLUME, areaInt(volume fraction)@AREA or lineInt(volume fraction)@LINE.
March 6, 2019, 11:09 |
free surface monitoring
Aashi
Rep Power: 7 |
hello sir thanks for your kind reply i have already inserted the volume integral as an expression in cfx pre but it does not include the height of fluid during sloshing means sloshing wave height sir i want to have display of sloshing wave height vs time and also with respect to tank wall height how is this possible in cfx thanks in advance
March 6, 2019, 16:30 |
Rep Power: 143 |
Please define mathematically what you mean by sloshing wave height and height of fluid during sloshing.
March 8, 2019, 13:43 |
Chart of free surface
Aashi
Rep Power: 7 |
sir i want to track the movement of free surface which is shown in the figure attached below i want to draw the graph of maximum movement of free surface vs height of tank please guide me how to draw the graph in cfd post
March 9, 2019, 04:58 |
Rep Power: 143 |
Your definition is not very clear.
Maximum movement of what? Does this mean the highest point of the surface? Or a selected point? Or a point which has the largest difference between maximum and minimum heights over time? Assuming you mean the maximum height of the surface, then define a variable maxVal(y)@<FREE SURFACE ISOSURFACE OBJECT NAME>, then generate a chart using this as the vertical axis and time as the horizontal axis.
cfx |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
