How to pass variable value obtained in iteration n to iteration n+1 |
April 11, 2019, 05:56 |
phd
Rep Power: 12 |
Hello, guys
I am running a steady state simulation and have defined an additional variable X. If I need to use X obtained in n_th iteration/time-step for the simulation of the n+1_th iteration/time-step, how can I pass/inherit this value, X(n), to the next iteration? One way I can think of is to run the simulation for just one time step each time and use the correspondingly generated .res file to output the X(n). But clearly this will be extremely computational inefficient. I’m wondering if there is any way that we can pass/inherit the variables between iterations without stopping the simulation. Can User Fortran/Junction Box do that? Thank you very much! |
April 11, 2019, 07:29 |
Rep Power: 143 |
Yes, that would be very inefficient.
Do a search of the forum for TRANS_LOOP. This is a unsupported feature which allows some variables to be accessed from the previous coefficient loop. But note it is notoriously unstable and does not always work (which is why it is not a supported feature).
April 11, 2019, 13:56 |
Rep Power: 33 |
It would great if you can explain why you need access to the previous iteration variable in a steady-state simulation.
In principle, previous values of a non-converged solution do not have great value unless is used for some kind on convergence improvement, so I assume you must be up to something, correct? |
April 11, 2019, 14:00 |
phd
Rep Power: 12 |
Hi, Glenn
Thank you very much for your reply. It seems to work for me! Can I also confirm one thing with you: if I use Trans_loop for my variable X, at the first step will this X use the value of the initial guess? What if in the initial guess X is not define? |
April 11, 2019, 17:07 |
Rep Power: 143 |
I have no idea, it is not documented. You just have to try it and work it out.
April 12, 2019, 06:27 |
phd
Rep Power: 12 |
Thanks! I've tried. it works in that way
additional variables |
[General] Pass variable from programmable filter to Plot Over Line Filter | Jack001 | ParaView | 0 | March 29, 2016 13:18 |
How to pass variable between macros | einandr | Fluent UDF and Scheme Programming | 1 | February 5, 2015 06:34 |
Best way to pass a scalar variable to a runtime selectionnable class? | Yann | OpenFOAM Programming & Development | 0 | October 22, 2014 08:53 |
Pass a variable from a class to a subequation in the main solver | lord_kossity | OpenFOAM Running, Solving & CFD | 0 | September 3, 2009 12:03 |
How to pass a variable from a define macro... | Padian | FLUENT | 2 | May 30, 2008 05:22 |
