June 24, 2019, 08:45 |
Von-Karman Vortex shedding
omid
Rep Power: 6 |
Hello
I'm trying to simulate FSI example proposed by Turek-Hron in which flow over a cylinder causes vortex shedding behind the cylinder. When I simulate this example using just CFD simulation (not FSI) with the velocity profile given in the article, I can see vortex shedding behind the cylinder. But whenever I add a beam shape structure behind the cylinder to run with the two way FSI approach, nothing happens behind the cylinder and I can not see Von-Karman effect. Does any one have any idea what should i change in my simulation. I'm attaching two pictures of my both simulations. |
June 24, 2019, 13:52 |
Erik
Rep Power: 23 |
Wouldn't the tail reduce/stop vortex shedding?
Also it looks like you have walls in the model with the tail on the top and bottom, but not in the one with just a cylinder? These walls could reduce vortex shedding as well, and should be moved further away. |
June 25, 2019, 02:49 |
#3 | |
omid
Rep Power: 6 |
https://youtu.be/15VOBaQ2oJY |
June 25, 2019, 07:14 |
Rep Power: 143 |
You never said the tail was flexible. This is a challenging simulation and you can expect to need to do some careful work before it is completed. I would recommend you do a static Von Karman vortex simulation and check you can successfully model the vortex on a station before starting FSI.
When you add the FSI component start off with the tail quite mechanically stiff so it does not flex much. Once that is working then reduce the stiffness to the correct amount.
cfd, fsi 2-way coupling, two way fsi, von karman, vortex |
help!problems in simulationg von karman vortex street.Really simple.Thank you. | KevinW | CFX | 2 | July 17, 2013 21:08 |
Alejandro Selkirk Island Von Karman vortex street | epik | Main CFD Forum | 1 | May 31, 2012 22:09 |
von Karman vortex street. Vortices formation mechanism. | mnvl | Main CFD Forum | 1 | February 24, 2010 17:53 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
Von Karman 2D Stable, no shedding | Stephen Mar | FLUENT | 3 | March 16, 2004 14:48 |
