Some questions about working in Ansys
Old   April 27, 2019, 07:21
Default Some questions about working in Ansys
Valera
looee is on a distinguished road
Hi Everyone!
I have some questions about Ansys:
1) Can I work in Ansys table like in Excel? For example, what should I write in B32 cell to calculate it as =B31*(B28-B29)
2) In my work i have pipe counter heat exchager. I want to caclucale the total heat, which is transfered from hot water to cold through the pipe. To do this I've calculated the average heat flux through the pipe interface and multiply it to its area. But can I calculate it in one step? I didn't find corresponding function.
3) What should I do to change the temperature unit [K] to [C]? I changed it in the “variables” window, so the results in the chart (for example) are displayed in [C], but [K] still remains in the table
looee is offline   Reply With Quote
Old   April 28, 2019, 18:53
Tomer Simhony
FluidViscosity is on a distinguished road
To answer two of your questions:
1) Yes and no. Have a play with it and you will quickly see its limitations. To my knowledge you cannot reference other cells, but only expressions, variables, locations etc. To achieve what you want instead write something like =massflowinlet*(enthalpyinlet-enthalpyoutlet) if you are using expressions. Otherwise the full expression using functions.
3)You can edit the units by going Edit/Options/Units in CFD Post, or changing your solution units before the solve in CFX Pre. E.g. change these in your .ccl:
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
FluidViscosity is offline   Reply With Quote
Old   April 29, 2019, 09:54
Valera
Thank you for advice!
But in Edit/Options/Units in CFD Post there is no choice between [C] and [K]. Just only [K]
Old   April 29, 2019, 17:18
Tomer Simhony
Almost there!
You simply need to change the system from SI units to 'custom' to allow the temperature unit to be in degrees Celsius.
Old   April 30, 2019, 07:57
Valera
Oh, exactly. But in chart it's still remaning [K]
Old   April 30, 2019, 16:50
Tomer Simhony
Strange. For me it automatically updates when I hit Apply/OK. Try right clicking 'Chart 1' in the outline and selecting refresh preview. If that still doesn't work, I would export the data as a csv and change it manually.
File/Export/Export...
Old   May 2, 2019, 02:53
Frank Weise
FrankW is on a distinguished road
You can also change the units at the Variables Tab.
FrankW is offline   Reply With Quote
Old   May 2, 2019, 04:25
Valera
Yes, I mentioned above about it. Nonetheless units haven't change in the Table, although it works for all others (for the countours and for the Charts)
Thank you)
Old   May 2, 2019, 04:37
Valera
I confused Table with Chart. In the Chart it works, but in the table units haven't changed
Ansys WB has stopped working geethu ANSYS 3 November 1, 2017 14:12
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 00:17
ansys help viewer has stopped working haydaraslanersin ANSYS 0 June 21, 2016 09:14
How to reset the defulat layout of Ansys working bench jatin1990 ANSYS 1 August 27, 2014 02:57
ANSYS program has stopped working? chihoangkt ANSYS 0 July 16, 2012 16:41
