June 12, 2019, 15:46 |
One Mesh - Two Boundaries
Michael Hopfinger
Rep Power: 9 |
Dear all,
is there a chance to apply 2 boundaries conditions to one mesh 2D region? For example I have got a round outlet but the flow is only allowed to flow through the upper semi-circle and the lower semi-circle is treated like a wall? I want to avoid to use a know mesh. I was thinking about a user surface but don't know how to apply a boundary condition to it. Thank you. |
June 12, 2019, 15:48 |
Rep Power: 32 |
If you know it is a semi-circle, you must split the circle into two parts, then apply boundary conditions for each separately.
June 12, 2019, 15:55 |
Michael Hopfinger
Rep Power: 9 |
But I can I split the boundary somehow in CFX-Pre by a user-surface or do I need to come up with whole new mesh?
June 12, 2019, 18:58 |
Rep Power: 143 |
You need to do a new mesh.
June 13, 2019, 02:47 |
Gert-Jan
Rep Power: 27 |
1) remesh the thing.
2) Don't know the source of the mesh, but you can try to import the mesh in ICEM, put the wall elements in a new part, export the mesh and you have what you want. 3) Alternative escape: draw a cube, mesh this as a solid block, import it into pre and position it as an immersed solid on your outlet to block the upper or lower part. This is quick and dirty, and not very accurate, but might be a viable escape, if you have not other option left. |
June 13, 2019, 03:35 |
Michael Hopfinger
Rep Power: 9 |
Thank you very much. Then I know what to do
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[ANSYS Meshing] What and how to use sweep mesh by inflating the boundaries? | alvinthum | ANSYS Meshing & Geometry | 2 | March 26, 2018 05:30 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
