September 19, 2019, 09:23 |
CFD-Post run session on hpc
Thomas
Rep Power: 8 |
Dear all
Currently I have a large transient simulation which I try to post process in CFD-post. However as this can be tedious I am exporting data from multiple planes in the domain through a session file (perl script). This works fine if I have only a few planes. However I need to do the same for a large amount of planes (>100). This takes time and the workstation is hammering my harddrives as it accesses every time step individual. So my question is how can I do exactly this but on an hpc. This may not go quicker but it is of my computer. Does anyone know how I can run CFD-post on the hpc, load a results file and play a session file? Thank you for your suggestions. |
September 22, 2019, 19:19 |
Rep Power: 143 |
You might also consider a high-end post processing package like Ensight, Fieldview or Tecplot. They have are designed to handle massive data sets.
September 23, 2019, 13:20 |
Erik
Rep Power: 23 |
Working off a SSD or RAID SSD will also speed this up compared to using hard drives. What type of drive is the .res file and transient files saved to?
October 3, 2019, 10:02 |
Thomas
Rep Power: 8 |
Thank you very much for your replies. I agree with all suggestions. Working of an SSD definitely helps and a different post-processing package as well. The reason for moving the post-processing onto the HPC is not necessarily to speed it up, but to free local resources.
I did see that cfd-post can be run through the command window and I tried the following: #!/bin/bash #SBATCH -p hipri #select partition (hipri, medpri, lowpri) #SBATCH -J Post #Job name #SBATCH -o slurm-%j.out #Output #SBATCH --nodes=1 #number of nodes #SBATCH -n 1 #number of cores #SBATCH -t 0-00:10 #time (D-HH-MM) module load ansys/182 #SBATCH -cwd cfx5post -batch HPC.cse where HPC.cse is the session file I want to run. However I get the following errors: viewer_ogl.exe: cannot connect to X server localhost:13.0 Socket::waitForConnection - Connection timeout after 120s I assume that this has something to do with the interface. I am using PuTTY and have enabled X11 forwarding. Technically I don't need an interface but I assume that CFD-Post only runs with and interface? How do I set it up correctly so I can run it on the HPC? This afternoon I was able to run exactly what I want to do on the cluster on my local machine through the command line window. I did notice that I had to adjust a few commands. But with the fillowing command line it did work on the local computer: cfx5post -line -batch HPC.cse Test.res However when running on the HPC I still have the same issue described above. Does anyone have an advice? Last edited by hand90; October 3, 2019 at 12:16. |
cfd-post, hpc |
CFD Salary | CFD | Main CFD Forum | 17 | January 3, 2017 17:09 |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 07:23 |
Shall I leave one core free when I run CFD simulation? | Pierre1 | Main CFD Forum | 1 | March 12, 2015 04:46 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 00:30 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
