How to set water level in basin solar still? |
September 25, 2019, 11:20 |
Aja
Rep Power: 14 |
I am simulating basin solar still using CFX. But I don't know that how to set water level in CFX? The water level inside the basin is 4 cm (in direction of Y). Thanks. |
September 25, 2019, 12:47 |
M
Rep Power: 12 |
Use a step function inside an expression to initialize the water phase volume fraction below a given spatial coordinate value:
myIniWaterLevel = step(<Offset> - Y Coordinate) Within the global initialization you can use this expression to give the initial water volume fraction. Also initialize the correct pressure distribution (due to hydrostatic pressure under water). Define the air volume fraction to be one everywhere else. There is also a cfx tutorial on this, so you might find a template there. |
September 25, 2019, 13:33 |
#3 | |
Aja
Rep Power: 14 |
Thanks. Could you please explain more about "step(<Offset> - Y Coordinate)"? The water level is between 0 and 0.4 in direction of Y. I have the following error: |
September 25, 2019, 17:37 |
Rep Power: 143 |
When you are using a CEL function you should look up the documentation (reference manual) so you know the syntax and what it does. You just need to get the syntax right. Also your error message says you need to fix the units - again refer to the documentation on why that is, it is all explained there.
Try myIniWaterLevel = step((y-0.4[m])/1[m])
September 27, 2019, 07:14 |
#5 | |
Aja
Rep Power: 14 |
Which CFX tutorial? |
September 27, 2019, 07:49 |
Aja
Rep Power: 14 |
Now I have following error(but still prior problem is investigating):
Why dose this happen? error mean that it should be define viscosity for glass and wood. But I don't see viscosity in their properties(material tab). thanks. |
September 27, 2019, 08:04 |
Gert-Jan
Rep Power: 27 |
Open the transport properties tab of glass and wood
September 27, 2019, 08:08 |
Gert-Jan
Rep Power: 27 |
September 27, 2019, 08:52 |
#9 |
Aja
Rep Power: 14 |
Firstly I should say that this simulation is steady. About water level, I write expression as flows:
But water volume fraction is as follows. This value of water height is very small. Also, I increased value of waterH (initial water height) but the problem is not solved. How can I solve this problem? Thanks. Last edited by aja1345; September 28, 2019 at 07:01. |
September 27, 2019, 09:03 |
#10 |
Gert-Jan
Rep Power: 27 |
You mentioned the liquid is 4 cm. So, looks ok. For someone who is not involved in your problem, this can be a completely valid outcome of the simulation. Since you are the only one involved, it is only you who can judge its validity.
So, if you need help, go to your supervisor or describe exactly what you are trying to do, what you expect, what inlet and outlets are, boundary conditions, etc. I have no idea and don't want to guess. |
September 27, 2019, 09:32 |
#11 |
Gert-Jan
Rep Power: 27 |
Also, show your grid.
September 27, 2019, 10:28 |
#12 |
Aja
Rep Power: 14 |
September 27, 2019, 10:33 |
#13 |
Aja
Rep Power: 14 |
Hi again
I want to allocate glass material to glass boundary (according to the following pic), but I can't do it. In fact, I don't find anything about material in the boundary. How can I solve this problem? Thanks. |
September 27, 2019, 10:50 |
#14 |
Gert-Jan
Rep Power: 27 |
You can only assign material properties to volumes, not to surfaces.
But why would you include glass? I really wonder: What question are you trying to answer using CFD? Do you have this point sharp? |
September 27, 2019, 12:01 |
#15 | |
Aja
Rep Power: 14 |
I want to develop a steady three-dimensional, two-phase model for evaporation and condensation processes in solar still by using (CFD) method to simulate the model. |
September 27, 2019, 13:43 |
#16 |
Gert-Jan
Rep Power: 27 |
What you describe is the piece of equipment.
But what question do you have about it? Is there something wrong with it? Or do you just perform a CFD calculation to be of the street? |
September 27, 2019, 17:12 |
#17 | |
Aja
Rep Power: 14 |
This is a MSC Project and I should valid my work with a paper and then I want to develop this work and investigate different effective parameter on still performance, for example: depth of water(water hieght), glass boundary slip and ...therefore, firstly, I should valid my work. I solved some problem in this case with help of you and CFD online, But Now I have just one problem and it is depth of water. In fact, I don't know that how can I change this depth with using expression. Thanks. |
September 28, 2019, 05:27 |
#18 |
Gert-Jan
Rep Power: 27 |
How much is 0.08 [cm]?
September 28, 2019, 06:04 |
#19 |
Aja
Rep Power: 14 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 14:27 |
For a single phase flow, is there any way to check water surface level? | Tanjina | FLUENT | 0 | February 23, 2014 22:56 |
How does one set an inital water level for a tank | FreeFall79 | CFX | 1 | November 19, 2013 17:53 |
height of water level in two-phase flows? | Michael Bo | CFX | 2 | August 23, 2004 01:50 |
