December 26, 2019, 18:38 |
Stopped in routine get_INSIDE_IMS
Kim Gunhyeong
Rep Power: 7 |
Hello
I performed Immersed solid - rigid body solution and applied external force(Expression : force_y()@some domain) on rigid body Then error massage printed : stopped in routine get_INSIDE_IMS If I turn off external force, simulation proceed well. What is problem? |
December 27, 2019, 04:06 |
Rep Power: 143 |
force_y()@somewhere returns the force on a surface, it does not sound like a function you would use to set a force on an immersed solid.
December 28, 2019, 06:19 |
Kim Gunhyeong
Rep Power: 7 |
Hello ghorrocks
The pressure acting on an immerged solid by a fluid was returned through force_y@somewhere and then applied to an external force(y = force_y()@somewhere [N]. |
December 28, 2019, 18:50 |
Rep Power: 143 |
Why do you need to do this? The force acting on an immersed solid is automatically applied to the solid, this is how immersed solids work. Can you explain why the built-in function does not work for you?
December 29, 2019, 12:17 |
Kim Gunhyeong
Rep Power: 7 |
Really? I misunderstood immersed solid reation againat fluid. I will try again.
Thanks bro. |
Stopped in routine ENFORCE_BOUNDS | camoesas | CFX | 21 | April 4, 2022 08:31 |
Error: Stopped in routine MEMERR | Gwandel | CFX | 13 | June 16, 2021 02:32 |
Stopped in routine Write_SurfaceUser | -Maxim- | CFX | 6 | December 7, 2016 06:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
