A question about source term
Old   April 10, 2006, 09:17
Default A question about source term
kirby
When I set CEL language about a source term of Reaction between propane and oxygen, the following notice appears frequently,then the calculation overflow.
Notice****** | Newtons method failed to converge in 100 iterations. This occurred while computing the following variable: | Variable Name :Temperature | Location Name :reation | Mesh location : VERTICES | Mesh entity : | Last 3 Changes : 1.59247E+33 1.59247E+33 1.59247E+33 | Tolerance : 1.0000E-02 | The Newton iteration was either slowly converging or has stalled. The solver will continue with the variable set as it was on the final iteration. If this situation continues you might try increasing the number of iterations allowed for Newtons method.This can be changed by setting one of the parameters: | Temperature : "Constitutive Relation Iteration Limit" Pressure : "Newton Pressure Iteration Limit" | | | for your mixture using the definition file editor.
What can I do, Thanks everyone!
Large source term in species equation MACFD FLUENT 4 January 4, 2011 14:16
additional subdomain source term YJZ CFX 1 July 13, 2010 19:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
UDF - Source Term Question Jacques FLUENT 0 December 8, 2008 13:40
UDF's - linearizing a negative source term Steve Howell FLUENT 1 March 18, 2001 16:21
