How to make the solver of CFX run automate
Old   April 9, 2006, 22:56
Default How to make the solver of CFX run automate
Jane
Hi
I want to know the flow field under different Re. I just want to change the inlet velocity, and use the same model. How to make the solver of CFX run automate? Can anybody give me some guidance or instructions?
I am using CFX5.6-Linux
Thank you very much in advance.
Old   April 10, 2006, 04:58
Default Re: How to make the solver of CFX run automate
James Date
All you need to do is write a batch file which modifies the .def file using the following command.
"C:\Program Files\Ansys Inc\CFX\CFX-5.7.1\bin\cfx5cmds" -write -definition run1.def -text Inlet_Velocity.txt
The text file is just ccl file which contains the new solver parameters i.e. the new inlet velocity.
James
Old   April 10, 2006, 11:38
Ogbeni
James, Is there a way to write out the monitor points as a file i.e as *.csv automatically ?
Old   April 10, 2006, 11:59
Ogbeni
Hello James is it possible to automate exporting the monitor points as well ? if so how ?
Old   April 10, 2006, 14:42
James Date
I think there is a command which can do this, its worth checking in the batch commands section of the manual. Failing that, you could just do it using CFX-post in batch. Create a session file where you output the valve in question to a .csv file then run it using the batch CFX-post command.
The ANSYS CFX solver exited with return code 1 kola77 CFX 24 April 11, 2022 07:32
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
[ICEM] Can it make extruded 2D meshes for 2D CFX simulations? siw ANSYS Meshing & Geometry 10 October 23, 2009 08:47
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
