July 4, 2023, 00:44 |
Turbulent Dispersion Model in CFX
Gyanendra
Rep Power: 2 |
Hello everyone,
I am using ANSYS CFX for simulating erosion problem of a pipe bend. In the particle tracking process, there are several forces (virtual mass, pressure gradient, turbulence dispersion) on particles which need to be considered while setting the problem in CFX Pre. For taking into account the turbulence dispersion, there is a model in CFX known as Particle Dispersion. Is this particle dispersion model same as Random Walk Model of Fluent? If not, where can I find it's expression? Thank you so much. |
July 4, 2023, 03:27 |
Rep Power: 143 |
Where can I find it's expression?
CFX documentation; Theory Guide, section 6.2.6. Is this particle dispersion model same as Random Walk Model of Fluent? Why don't you look in the documentation of Fluent and CFX and check for yourself whether the models are the same?
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 04:43 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
Turbulent dispersion of particle tracking in LES | mittal | OpenFOAM Programming & Development | 4 | February 23, 2011 18:01 |
