April 17, 2006, 08:51 |
Multicomponent Multiphase Reaction Modelling
I have a reaction of the form A(g)+B(g) -> D(g) + S(s). So, gases A, B,C ,D are components of a Reacting mixture(RMix). Ths solid S is a user defined pure substance.
When I define a multicomponent reaction, for the products, I select Rmix, S as the parent materials. D as child material for parent RMix. Although the CFX help manual says that the child and parent material of a pure substance should be the same, the child material list box for S is empty. So, I am unable to select it. How do I select S as the child material? Since I will be using the Eulerian Langrangian modelling, is it okay to use RMix in the fluid list & S as the particle in the Domain Definition? Should the solid S be defined as a user material or a particle solid? If it is defined as a user material, what should its dynamic viscosity be set as? |
Difference of multicomponent and multiphase homogenous flows | Luk_Fiz | CFX | 11 | April 4, 2013 05:29 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
Ansys CFX10: multiphase reaction heat problem | CFDS | CFX | 1 | September 20, 2006 23:09 |
Sources for multiphase multicomponent reaction sys | Liwau | CFX | 3 | May 20, 2004 23:08 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
