February 28, 2020, 15:27 |
CFX HPC License Usage Question
Tate
Rep Power: 11 |
I have a CFX license and a single HPC Pack license. From what I've read, this should allow me to use up to 10 cores. However, whenever I increase the number of partitions above 8, I get the following licensing problem error:
License Cap: ANSYS CFX Solver (Max 512K Nodes) License Cap: Multiple Reference Frames License Cap: Parallel ANSYS LICENSE MANAGER ERROR Not enough CFX Solver - HPC licenses 10/8. Dependent feature CFX_SOLVER_PAR_PRO C in AND keyword is not available. License ID: License checkout failed. Not enough CFX Solver - HPC licenses 10/8. Dependent feature CFX_SOLVER_PAR_PRO C in AND keyword is not available. +--------------------------------------------------------------------+ | ERROR #001100247 has occurred in subroutine . | | Message: | | | | The solver is unable to continue because of licensing problems. | | | | A license for the following capability level could not be checked | | out: | | | | ANSYS CFX Solver (Max 512K Nodes) + Licensed Models + Parallel | | | | Please carefully examine the error message output above and check | | that: | | | | 1) The license server is specified correctly and is running. | | | | 2) An appropriate license is available for checking out. | | | | These problems can be checked using the ANSYS Client ANSLIC_ADMIN | | utility. For further troubleshooting information please consult | | ANSYS, Inc. Licensing Guide. | +--------------------------------------------------------------------+ Is there something I need to do to activate the CFX and HPC Pack licenses at the same time? |
February 28, 2020, 16:20 |
Rep Power: 143 |
Where have you read the HPC license gives you 10 cores? Doesn't this error message say you just have access to 8?
February 28, 2020, 18:58 |
#3 | |
Tate
Rep Power: 11 |
The HPC Pack allows you to solve using 10 cores on your local machine. Additionally, while not explicitly for CFX, various websites (like the following) say that the HPC pack adds an additionaly 8 core capability: https://nimbix.zendesk.com/hc/en-us/...PC-Packs-work- However, the error message and the inability to run on more than 8 cores makes me think that I may actually only have access to 8. |
February 29, 2020, 03:55 |
Rep Power: 143 |
ANSYS changes the licensing rules all the time, and there are so many different license packages I don't bother keeping track of them all. So you are going to have to talk to your ANSYS account manager to sort this out as the licensing on your machine obviously thinks it cannot use more than 8 processes.
Question about solid part of CHT (conjugate heat transfer) in CFX | Anna Tian | CFX | 26 | November 15, 2023 12:28 |
HPC Cluster Configuration Question | chuckb | Hardware | 1 | September 8, 2018 08:26 |
Question about CFX user fortran | tengf689 | CFX | 8 | January 9, 2017 20:36 |
License problems in CFX 5.7 | Balaji krishnamoorthy | CFX | 1 | April 7, 2005 19:10 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 18:39 |
