May 29, 2006, 20:29 |
Porosity and buoyancy
hey,
Does anyone knows how to use buoyancy on a porous medium in CFX? Because, as soon as I add an isotropic loss model with a resistance loss coefficient, I get a big pressure jump on the interface porous-fluid... the pressure goes up to 40000Pa on the interface, whereas it's between 0 and 300Pa on the rest of the domain (which is in agreement with my boundary conditions). I tried to set the medium as non porous and I had no such dicontinuity. I also tried to put it porous but non buoyant, and I didn't have any discontinuity either. But when both are involved.... Does anyone has a solution? Can I set buoyancy in some domain only (the non porous ones) and not in others? Thanks, Guillaume |
June 3, 2006, 15:31 |
Re: Porosity and buoyancy
You need to switch to fleutn for this I think
June 5, 2006, 10:22 |
There is a bug when plotting hybrid pressure on porous interfaces in CFX... look only at 'conservative' pressures... hopefully the solution itself is ok... otherwise contact your support group.
June 5, 2006, 11:51 |
Thanks Donald. Very helpful and full of insight
Simulation of a Silo | Attesz | CFX | 20 | October 15, 2010 08:11 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
