CHANGING PROPERTIES FOR SOLID DOMAIN (CONCRETE)
Old   June 1, 2006, 18:22
Default CHANGING PROPERTIES FOR SOLID DOMAIN (CONCRETE)
CARL
Dear all
I need to model a building insulation problem. The question is how to 'type' the concrete thermal properties in the preprocessing stage. CFX only allows for Steel, Aluminum and/or Cooper for solid domains(do not remember if it is cooper or another very well... ), but I need to model other solid material properties.
Any idea how to do it?...
Kind regards,
PS: I know I should use interface boundaries at the air-solid-air interfaces...
Old   June 1, 2006, 18:55
Default Re: CHANGING PROPERTIES FOR SOLID DOMAIN (CONCRETE
Joe
You can create custom solids with arbitrary properties in the material library.
Material tab -> Click "Create new object"
CHT Problem - Domain Imbalance Parthipan CFX 5 September 11, 2007 10:13
Changing material properties lasb OpenFOAM Pre-Processing 1 August 13, 2007 08:52
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
Solver error message!!! IoSa CFX 1 September 14, 2006 04:48
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
