Simulating erosion on pelton buckets by silt laden flow
Old   May 11, 2020, 03:06
Default Simulating erosion on pelton buckets by silt laden flow
zehab
zehab is on a distinguished road
Simulating the erosion by virtue of sediment particles laden in silt water on the buckets of Pelton turbine in a steady state using Frozen rotor.
Performed the multiphase analysis (air+water) both as the continuous phase (Eullarian) with solid particle (particle tracking ).
When I do so the warning message pops out as "In Analysis 'Flow Analysis 1' - Domain 'Stationary': Particle tracking simulations with more than one continuous Eulerian phase are not supported".
Came across a document released by ANSYS 2016 (document attached) to tackle such warning. The method defined in that document is about changing expert parameters. I am not able to find the expert parameter "pt multiphase = t" and expert parameter "pt multiphase min volfrc = 0.5" mentioned in the document attached.
In addition to this I am a bit confused in choosing the following options
1. What reference density should I use?
a.) Air
b.) water
zehab is offline   Reply With Quote
cfx, fluid flow, particle transport
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
[rhoCentralFoam] simulating compressible inviscid flow Yuval OpenFOAM Running, Solving & CFD 2 January 27, 2016 21:33
simulating flow pyxbird FLOW-3D 7 October 24, 2012 11:30
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
