June 9, 2019, 08:36 |
Insufficient catalogue size
phd
Rep Power: 12 |
Hi there
I am using CFX(R) Interpolator to interpolate a case with many cooling holes. I received the warning message as shown here: +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Interpolator | | | | Release 17.2 | | Build 17.2 2016.07.18-16.51-136427 | | Mon Jul 18 17:04:39 GMTDT 2016 | | | | Executable Attributes | | | | single-64bit-int32-archfort-optimised-noprof-lcomp | | | | (C) 2016 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information at Start of Run | +--------------------------------------------------------------------+ Run mode: serial run Host computer: ENGS-19856 (PID:13084) Job started: Sun Jun 09 12:43:24 2019 +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ | Real | Integer | Character | Logical | Double ----------+------------+------------+-----------+----------+---------- Mwords | 32.56 | 23.22 | 3.69 | 0.01 | 0.30 Mbytes | 124.20 | 88.57 | 3.52 | 0.04 | 2.29 ----------+------------+------------+-----------+----------+---------- +--------------------------------------------------------------------+ | Host Memory Information (Mbytes) | +--------------------------------------------------------------------+ | Host | System | Allocated | % | +-------------------------+----------------+----------------+--------+ | ENGS-19856 | 49149.58 | 218.62 | 0.44 | +-------------------------+----------------+----------------+--------+ +--------------------------------------------------------------------+ | *** INSUFFICIENT CATALOGUE SIZE *** | | | | ACTION REQUIRED : Increase the file catalogue size. | | | | If the situation persists please contact the CFX Customer Helpline | | giving the following details:- | | Current catalogue size : 20000 | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = NDIM CDTYPE = INTR ISIZE = 1 CRESLT = FCAT Current Directory : /INTERP/OLD1/MESH/TSTEP0/CLOOP0/ZN44 WARNING: CFXSTP, Regression check error. An error has occurred in cfx5interp: The ANSYS CFX Interpolation Program exited with return code 1 Could you kindly tell me how to fix it? Thanks! Last edited by lostking18; June 10, 2019 at 16:13. |
June 9, 2019, 13:48 |
M
Rep Power: 12 |
I've not seen this error before, but there are similar errors regarding lack of memory. They can be fixed within the expert parameters tab in CFX Pre. I assume you will find a setting for the cataloque memory allocation there and might use factors like '1.3x' to increase it. https://www.sharcnet.ca/Software/Ans...oryconfig.html
June 9, 2019, 20:37 |
Rep Power: 143 |
Modelling 100 cooling holes is always going to be tricky. A good candidate for a reduced order model, most likely.
June 10, 2019, 07:37 |
Rep Power: 32 |
May I ask which approach are you using to model such cooling holes?
The message has no reference to the cooling holes; therefore, I assume the case works w/o any of the cooling holes being modeled. The message indicates there are at least 44 domains, are you modeling each hole coming from a different domain? |
June 10, 2019, 16:06 |
#5 | |
phd
Rep Power: 12 |
May 13, 2020, 12:13 |
Ganesh Arun Naik
Rep Power: 6 |
May i know how you solved the issue? Thank you
May 13, 2020, 16:24 |
Ganesh Arun Naik
Rep Power: 6 |
Thank you, I could find the option in expert parameters.
May 13, 2020, 17:52 |
#9 |
Gert-Jan
Rep Power: 27 |
You can also find them in the Solver manager. When you define a run, open "detailed memory overrides" tab for interpolation. There you can allocate extra memory for Catalogue Size. As we speak, I had a sucessful run today by setting '10x' there.
insufficient memory |
[Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 07:30 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
Error Message: INSUFFICIENT CATALOGUE SIZE | ahlo | CFX | 2 | December 14, 2007 15:59 |
Catalogue size problem but while meshing! | Jo Bouchard | CFX | 2 | December 28, 2005 11:32 |
