May 25, 2020, 11:54 |
Manual DES blending function
Jonas
Rep Power: 6 |
Is it possible to manually specify the DES blending function in parts of the domain whilst also having it calculated according to the normal expression in the rest of the domain? Many thanks for any input on this ! |
May 25, 2020, 14:00 |
Gert-Jan
Rep Power: 27 |
Not sure if the parameters can be a expression. If so, then you can make them depend on a coordinate using functions like step, max or min. And as such switch them on or off in a certain range of the coordinate....
May 25, 2020, 14:26 |
Jonas
Rep Power: 6 |
Hi Gert-Jan,
Thanks for your answer. I'm not quite sure I understand what you mean with 'parameters'? I assume you are referring to the expert parameters? I'm afraid I haven't found anything relating to the DES blending function there. |
May 25, 2020, 16:12 |
Gert-Jan
Rep Power: 27 |
If you select the DES model in CFX-Pre, you can open the advanced settings tab. There you can change e.g. the BF1 and BF2 values. I thought you mentioned these blend factors that allow you to control the DES simulation......
May 25, 2020, 18:12 |
Jonas
Rep Power: 6 |
I wanted to control the blending function directly (not through the SST shielding functionality). Though I must admit that your suggestion is very insightful and inventive, it will only allow me to switch to the very 'safe' F2 shielding functions, given a certain conditional expression is satisfied. Unfortunately, this will not allow me to set the DES blending function - only enable me to control the regions in which an SST blending function is used for shielding. If the solver clips the DES blending function at 1, then this could be bypassed by multiplying the conditional expression for the blending function factor by a large scalar. Thanks for your suggestion.
May 26, 2020, 02:34 |
Gert-Jan
Rep Power: 27 |
If you want more control, then you'd better program it yourself or switch to OpenFOAM.
blending function, des, manual |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
