rigid body motion with constant velocity
Like Tree3Likes
  • 1 Post By ghorrocks
  • 2 Post By ghorrocks
Old   August 12, 2014, 17:43
Default rigid body motion with constant velocity
aliali
ghoroobeaakhar is on a distinguished road
Hi
I need to put a constant velocity on my rigid body in one direction.
but I don't know where and how I have to do it?
thanks
ghoroobeaakhar is offline   Reply With Quote
Old   August 12, 2014, 18:56
Is it an immersed solid or a moving mesh rigid body?
Does the degrees of freedom controls do what you want?
If you have a rigid body in constant motion then it is not really rigid body motion and really just a moving mesh model. So you could just model it with moving mesh (or a pre-defined source term)
ghoroobeaakhar likes this.
Old   August 13, 2014, 05:59
aliali
Thanks.
I put one degree of freedom for it so It moves only in one direction.
I first simulate the body under gravity force and I got results but now I want to simulate the same body with a constant velocity (3 m/s) in the same direction.
I defined a rigid body and a wall condition for the surfaces of my rigid body.
In rigid body options I have an initial velocity and in wall condition's option I have specified displacement ans specified location. I tried to set specified displacement as 3[m]*t but it doesn't work.
how can I say to my rigid body that moves all the time in 3 m/s?
Old   August 13, 2014, 06:07
Try defining an initial velocity of 3m/s and give it a massive mass. Then the fluid forces acting on it will not affect it.
acasas and ghoroobeaakhar like this.
Old   August 14, 2014, 14:50
aliali
Thanks ghorrocks
I have another question. I defined wall condition for the surfaces of my rigid body and I need to calculate the velocity of the wall. I want to check that the wall is moving at 3 m/s .
In fact how can I know the velocity of the wall at every moment and acceleration of that?
Thanks
Old   August 14, 2014, 18:30
Have a look at the reference manual. It lists all the variables available on rigid bodies.
Old   August 20, 2014, 10:53
hamid
hhhhhsssss is on a distinguished road
Originally Posted by ghoroobeaakhar View Post
Thanks ghorrocks
Thanks
by output setting in cfx-pre or timestep selector in post or chart(transient xy....)
hhhhhsssss is offline   Reply With Quote
Old   December 23, 2014, 14:52
acasas's Avatar
Antonio Casas
acasas is on a distinguished road
Is it initial velocity set in Dynamic Mesh Zones/ Motion Attributes/Center of Gravity Velocity ?
I´m working under Fluent
acasas is offline   Reply With Quote
Old   December 23, 2014, 16:28
This is the CFX forum. Try the fluent forum.
Old   June 17, 2020, 04:13
Lauren Dransfield
ld1305 is on a distinguished road
I'm looking to do something similar - I have two bodies submerged in a field at a given velocity, and then need to be able to move one relative to the other along a prescribed path. I'm pretty sure I'd be able to do this kind of thing in Fluent, but can't see how to in CFX (and I don't have access to Fluent) as I only seem able to apply forces.
I'm hesitant to try the initial velocity and high mass approach as I need to change direction at some point. The only way I can think of doing that would be to have two simulations where the end of one is the start of the next.
I'd thought about trying to implement a constantly changing force profile, dependent on the velocity, but I'm not quite sure how to go about writing the function (and don't know if it's possible). This could also come into issues when I have to change direction, as this would be triggered by reaching a specified location, which I might not hit dead on depending on time-step etc.
Any advice is much appreciated
ld1305 is offline   Reply With Quote
Old   June 17, 2020, 05:45
This sounds like a moving mesh thing, not a rigid body thing. You can prescribe the mesh to move any way you like in moving mesh.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Stopping a rigid body in motion wade_doll CFX 13 June 30, 2013 07:47
Rigid body motion error when restarting a terminated FSI simulation lingdeer ANSYS 1 May 19, 2013 01:40
Rigid Body Motion Setup for Tesla Turbine me3840 FLUENT 0 October 26, 2011 17:54
Multi-Phase (VOF) & Rigid Body Motion in Star-CCM+ Star-CCM+ User Siemens 1 February 11, 2009 14:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
